Re: Checking clutch dog in cobra ?
The shift cable from engine to outdrive should be red, if it has a black cable, needs updated shift cable. There is a web site about shifting problems and jumping out of gear, someone may post the address. Jumping out of gear may be caused by incorrect cable, cable adjustment, incorrect gear set( should have changed under warranty), worn clutch dog/farward gear, shifter shaft and belcrank.
