Re: Checking and changing the lower unit oil on a 62 Merc 800 80hp
Hi Oldmerc80<br /><br />There are two plugs on the lower unit, one is a drain and the other is a vent. Whipper is correct about the color. Use "Quicksilver" Gear Lube. It comes in soft tubes. One should do it for your motor but get two just in case. To drain the oil take the drain plug out and then the vent plug and tilt the engine so that the drain hole is at the lowest possible point. After drainned, replace the vent plug. To fill return motor to zero tilt position, cut the tip of the soft tube and stick it in the drain hole, whith the tube firmly in tht drain hole unscrew the vent plug (But not completely) and squeeze the tube. Stop when oil starts comming out the vent hole (This might take more than one tube of oil but I doubt it, My 140hp takes two and it's a big gear case). Tighten the vent screw and remove the tube from the drain hole. loosen the vent screw and let approx 1/8 - 1/4 inch drain out of the gear case then tighten the vent plug and replace the drain plug. This allows for heat expansion.<br /><br />Hope this helps and good luck
