sailsmanship
- Jul 26, 2000
- 389
I have a Faria SS Chesapeake guage set that is three years old and the tachometer is not working properly anymore. The hour meter in the lower middle works, and the tach needle moves a little through the rpm range and then sticks in the 1500 rpm position when turned off. The setting is on 8 cyclinder which the motor is. Is there any way to test if it is the tach or the sender before I buy a new tach. Also I checked all the connections and they seem good.
