Check Eng Alarm/Light
Elbowroom
I have a 1996 Ocean Pro 200 HP engine. At high speed the Alarm comes on and when I slow down it goes goes off. I have checked for water in the fuel and have replaced the spark plugs and thermostats, water/fuel separator and water pump. I have disconnected and reconnected the exhaust sensors without any luck. Someone told me to check the VRO. What is it and where is it? Also, what other sensors should I look at. This is a carbed engine, no fuel injection. No other alarms are coming on. Any suggestions?
Fed
Re: Check Eng Alarm/Light
What alarm is it?
A continuous tone Beeeeeeeeeeeeeeeeeeeeeeep
A beep every 30 secs or so Beep......Beep......Beep......Beep
A rapid beep rising & falling with RPM Beep.Beep.Beep.Beep
I'm guessing continuous which will either be temperature or fuel vacume.
If it stops as soon as you slow down I'm guessing fuel vacume switch which would indicate blocked tank vent, blocked fuel pickup, stuck anti-syphon valve, blocked fuel filter.
Hope this helps.
Chris1956
Check Engine Alarm is a fuel restriction. Check the filters and antisiphon valve for dirt and clogs.
bob johnson
ther fuel restriction alarn is the same as the over heat alarm but only happens at high rpms....
since yours goes off when you slow down...thats a good sign it isnt the over heat alarm...
which is like 240 degrees!!!!!!! and it doesnt go off till it drops to like 215 degrees!!!!
, I would aslo suggest checking your fuel delivery
bob
d.boat
the fuel restriction alarn is the same as the over heat alarm but only happens at high rpms....
bob
I agree on everything except that 1996 engine as OP describes has the "system check" alarms with indicator lights. The overheat alarm lights over heat, the fuel restriction alarm lights the check engine light (as indicated in title). So, the overheat and fuel restriction alarms aren't the same w/ system check. Pre-system check alarms were horn only and what Bob wrote is right on for them.
First advice, get yourself a factory service manual or at least an owner's manual for that engine. Understanding warning signals and lights is basic owner information which is included in those manuals. There's also basic maintenance info. I found an owner's manual for my older Johnson engine on ebay, but are also available through other sources. It is handy to have and would have saved you a lot of wasted effort and money working on things that don't affect this warning signal you're getting.
Here's a helpful article too: http://continuouswave.com/whaler/reference/VRO.html
As others have said, that particular alarm indicates a fuel restriction which not only has nothing to do with the VRO/OMS pump, it would also have to be corrected regardless of whether you changed the pump or discontinued the oil mixing system. It's a common claim of failure on the part of the VRO/OMS by people who don't understand it and an erroneus reason people use to discontinue automatic oil mixing.
Some common causes are restricted air vents in fuel tanks (can get plugged w/ critters nests), clogged or poorly installed fuel or water separating filters (which I strongly recommend if you don't have one!), faulty anti-siphon valves, fouled fuel pick ups in tank.
All that stuff is easy to check and correct.
Is this a new problem? If so, has anything changed?
BluefishBoy
Check your primer ball to, they do fail and it's not always noticable when they do.... If you have to start somewhere, start cheap and the primer ball failing can lead to that alarm
daselbee
Exactly as quoted above. Agree 100%.
