Cheap trim & tilt oil for OMC Cobra ?
Igofaster
Hello, I got a slow leak from one of my steel-braided hoses right where it goes into the hydraulic cylinder. I just had the drive off for replacement of shifter cable, And dont have the money to replace the hose yet. So what is a cheap oil I can use for the hydraulic trim and tilt, the omc oil is like $10 a small bottle and about 20 miles away from me to buy. What oil can I use ? Its a 87 cobra 2.3. Thanks
Autotech1
Re: Cheap trim & tilt oil for OMC Cobra ?
the oildyne and prestolite used by mercruiser can use 10-30 or 10-40 according to the mercruiser manual. dont what pump you have tho. a good manual should give you an alternative (for emergencies).
I think well just use the 10-30 rather than paying out the arse for mercruiser products.
Autotech1
the oildyne and prestolite pumps used by mercruiser can use 10-30 or 10-40 according to the mercruiser manual. dont what pump you have tho. a good manual should give you an alternative (for emergencies).
bruceb58
If it were my boat, I wouldn't be running it with a leak in the first place. Just wait and get your line fixed before you use your boat anymore.
Tranny fluid is what you want to use.
Ayuh,...........
You Just need a New Line Now,........
Keep runing it,+ it'll be needing Possibly Rams or a Pump.......
If Oil is leaking Out,....... Water will be Leaking IN.......
Igofaster
does the Drive has to come off to replace the outer steel braided lines?
Autotech1
not sure about OMC. mercruisers dont have to tho. I just replaced 3 and ordered the 4th. plain old back hoses were only 19 bucks. braided stainless from merc were $33. we already had one new stainless in the package and the two i bought online turned out to be black rubber and poly cord.
Ill have one black and one stainless one each side, doesnt look bad.
Look around online, not sure if Iboats will have stainless.
If one hose is bad might as well repalce them all as they are likely same age. The inners are probably ok as they dont flex and they dont get sun and water.
Autotech1
Ok this is from eBasicpower.com
Hose, Power Trim for OMC Cobra, Starboard Down
Part Number: MAL9-71602
Price: $33.20
Quantity in Basket: none
Power Trim Hose for Cobra, manifold to cylinder (starboard Down)
OEM: 983946
Hose-Power Trim, OMC Cobra, Starboard Up
Part Number: MAL9-71603
Price: $29.99
Power Trim Hose for Cobra, manifold to cylinder (starboard up)
OEM: 983947
Hose-Power Trim, OMC Cobra, Port Down
Part Number: MAL9-71604
Price: $30.76
Power Trim Hose for Cobra, manifold to cylinder (port down)
OEM: 983948
Hose-Power Trim, OMC Cobra, Port Up
Part Number: MAL9-71605
Price: $31.50
Power Trim Hose for Cobra, manifold to cylinder (port up)
OEM: 984024
Autotech1
Ok here in the same order is the #s and prices for Iboats
18-2132 Trim Hose
Part # 18-2132
$38.19
Compare at $44.99
Replaces OEM part #
* OMC 983946
* OMC 985614
* VOLVO 3853854
18-2133 Trim Hose
Part # 18-2133
$34.41
Compare at $40.49
Replaces OEM part #
* OMC 983947
* OMC 985615
* VOLVO 3853855
18-2134 Trim Hose
Part # 18-2134
$35.55
Compare at $41.99
Replaces OEM part #
* OMC 983948
* OMC 985616
* VOLVO 3853856
18-2135 Trim Hose
Part # 18-2135
$36.46
Compare at $42.99
Replaces OEM part #
* OMC 984024
* OMC 985617
* VOLVO 3853857
Gary H NC
Plus when you fix the leak the OMC service manual states you can use regular ATF in the system.
Igofaster
Thanks, For now I filled in the area with 5200 sealent and am going to keep it full with ATF.
Don S
5200 Does NOT stick to an oily surface, and was never designed for or expected to repair hydraulic pressure hoses or fittings or the cylinder itself. Who knows, if you cleaned the area with Acetone, maybe, just maybe it will keep rain water out. But that is all that repair will be good for.
Ayuh,...
You'll be Replacing More than just that Line in a Short Time..........
San Diego,........ Are you boating in Saltwater,..??..??....
It Might be Toooo Late Already......
Darkhorse1201
Hey - since its an OMC the one thing that nobody has mentioned here is that those hoses use tiny o-rings ate the ends to seal them. If its leaking where it screws in and they haven't been replaced in a long time they leak! And a very small o-ring is alot cheaper than an new hose anytime! Just my 2 cents worth!
Darkhorse1201
Autotech1
Could be thats all it is then. Im not familiar with OMC tho.
