kungpaoshizi
- Apr 29, 2013
- 221
Got the grill at that W place... otherwise wanted a stabile setup since fire on a boat doesn't mix...
Used 1/4 inch bolts with a washer on the inside, had to take out the grill innards..
On the outside it's a lock washer and a nylon nut (for extra security and you don't want the bolt falling inside) followed by the seat mount and then a larger washer and a wing nut. This allows for you to take the pedestal off the grill for storage.
The red marks on there are going to be a simple aluminum bar attached somehow to the end wing flaps for extra stability and it will make a little corral for stuff on the grill so it doesn't slide off in case of unforeseen wake.
