Chattering in lower unit BF135
ok so i bent my prop shaft a couple months ago... i ordered a new shaft and all the seals needed to replace once i take it all apart and a new impeller at the same time (also put a stainless prop on her if that matters). I got it all back together and took it out and when i put it in gear it chatters pretty bad... when i give it some gas it smooths out but some times when im at idle (trolling) it will start doing it again.... i can give it some more gas and it will go away. any time i switch from forward to reverse it comes back. what is going on? gears not going together right? bad bearing? a side note when the bent shaft was in there it did not chatter... just vibrated steadly in accordance with speed.
tommays
Re: Chattering in lower unit BF135
Just kind of wondring how you set the gear and bearing clearances :confused:
well everything is press fitted and not adjustable with the exception of a shim at the very front of the case. i figure if i took a shaft out that was straight (before i bent it) and put a straight one in i shouldn't have to change that...only if I am changing the gears/bearings....or maybe if i changed that carrier then you would change the shim too. am I wrong?
JUSTINTIME
did you use the factroy manual and specs???
ya there werent any specs except for bolt torquing specs. I bought a honda manual and followed everything exactly....it has step by step proccess for changing a propshaft.
