Charging Voltage
I have a 97 Johnson V-4 115. My batteries keep going dead. I Checked the batteries with the motor running and I did not see a increase in Voltage. What would the voltage be if my regulator was working? Is the Regulator what charges my batteries?
wilde1j
Re: Charging Voltage
13.5 VDC + or > across the battery terminals. Regulator and/or stator, poor terminations, etc. can be the cause. If no or low stator AC voltage, the stator is NFG.
Jim
Barnacle_Bill
Test your rectifier. They are usually the first to go. Especially if you have ever hooked the battery up backwards, even for a split second.
BoatBuoy
Also, you may not see any voltage increase at idle, only at a bit higher RPM.
jtexas
you have a rectifier/voltage regulator to charge the battery...I agree w/bpile...even at idle you should see some charging voltage on the battery and the rectifier is the prime suspect...tach usually goes out at the same time. Have a ohm meter? Test the rectifier.
If you have wing nut connections to the battery...make sure they are good and tight...use pliers...that sort of thing can smoke the rectifier.
wilde1j
Better yet, take the wing nuts and throw them as far as you can and replace with SS hex nuts, washers and tighten with a socket.
DHPMARINE
Thanks !! Actually you don't have to throw the wing nuts that far.Give them to someone you dislike,and leave it at that.They should never have been put on a marine battery PERIOD
DHP
or the battery should come with pliers (?)
DHPMARINE
Sorry Killer,I do get off topic sometimes.
Put a volt meter on your battery.You'll see 11.5 to 12.6 or something.Crank and start the motor,you'll see the voltage drop,then return to where it was.
Rev the motor slightly,and the voltage will go up some.If not,yes you have a problem.
DHP
