Re: Charging Voltage
Your charging system should have about a 9 amp output so don't expect too much. If your tach is not working, it sounds like your stator went south. Check your manual and find the two wires coming from the stator to the rectifier/regulator and measure the AC voltage coming out. You should have about 22 volts AC at these wires. If you do, the check the voltage coming from the rectifier, it should be about 15 to 16 volts DC. If you have a seperate regulator, check the voltage coming from that, it should be about 14 to 14.5 volts DC. A regulator is not needed since the output is only about 9 amps. You can also by diode bridges and regulators from electronics houses that will handle 10 amps. Much cheaper than OEM and work very well. Been there and done that one.
