charging trolling motor batteries
blacktrain
My trolling motor is 24 volt, is there a way I can charge the batteries with a battery charger without having to remove the cables from the batteries and charging them separately? Thank you...
Alumarine
If you have two 12 volt batteries making up the 24 volts you can just hook the 12 volt charger up to each battery individually.
No need to disconnect them.
