Not sure if its a maintainer. it says its a fully automatic battery charger but it is probably 10 years old (grabbed it from my parents house) sears model number 200.71212
ok found the manual online for it. Supposidly it stops charging when the battery is fully charged so I can just leave it. Now the only question is do I trust a 10 year old charger to stop on its own lol
I would not leave it on after the battery is fully charged.
I would put a meter on the battery and see if the voltage is over 14 volts.
If it is I would disconnect it and then charge again the next month.
Automatic Battery charger from that generation will fully charge and taper to very low amps but still hold the battery over 14 volts.
While that will not destroy the battery it is still using house current and not helping the battery.
Battery maintainer voltage is usually about 13.2 volts today.
Three stage chargers will charge as high as 14.8 volts then drop to a lower voltage like 13.2 volts for sometime then most turn off until the voltage down to a voltage around 12.6 volts.
Your's will not over charge like a trickle charger will. Trickle charger offten the voltage climes to 16 to 18 volts.
If you found a manual on line does it say to leave it on the battey forever?
Buy a self timer and set it for 8 hours.Then buy a load tester $20-30 at Harbor Freight.
Then a cell tester.(Hygrometer??)
As long as the battery is charging it will be cooking the juice inside.If you leave a trickle charger hooked up,keep an eye on the water level in the battery.If it gets low add distilled water.J
Or...you could just unplug it after 6-10 hours and forget the rest. Check cells with a hydrometer if it doesn't hold a charge. A $5 cheapie multimeter will let you know stored/charging voltage.
