Charging system.
Status
Not open for further replies.
reflexx90
I own a Bayliner reflexx, it has a merc sportjet 90. being that this is the first jet boat I've<br />owned I don't know much about it. I just bought<br />it, had it out 3-4 times no problem,the next time<br />I take it out dead battery!<br /><br />Buy new battery run it off and on all day no problem,shut it off for 10 minutes,try starting<br />dead battery. Whats up? I was told the stater<br />might be bad. but batterys keep dying HELP! :confused:
reflexx90
Re: Charging system.
What does that do? <br />where is the rectfier? how do I check it?<br /><br />THANKS TONS
Trent
The rectifier converts AC voltage from the stator to DC voltage to charge the battery. However these engines have had stator problems. Check the rectifier first.
reflexx90
Do I have to have a mechanic look at it or is there a way for me to find out on my own whats wrong? Because I like everyone else hate to part with hard earned money.
rami
I know where he can put that canoe... Let's be civilized, some of us don't know much about this and the sarcasim does'nt help. :(
reflexx90
Well you know I also have a 1973 aristocraft<br />with a merc 165 straight 6 that is pretty easy to diagnose these jet powerheads are new to me.<br />I don't mind spending money but I don't want to go broke either. But thank you at least now I <br />know the caliber of people that I am asking for<br />help from. Its funny how one person can ruin<br />an otherwise useful tool don't you think? :p
osdustin
dont worry it is no big deal to fix there isnt much to go wrong. but as for sea wolf i think he has a hole in his water wings.
reflexx90
Thanks alot osdustin hopefully I'll get it figured out soon I need to get back in the water<br />I know where the voltage regulator is as well as the stator but where in the world is the rectifier? Thanks for all your help. :confused:
craigy
osdustin, maybe sea wolfs water wings dont have a hole in them, maybe he just overfilled them ?
Trent
Voltage regulator/Rectifier can be the one and the same. I dont have a manual for your setup, But they work almost the same.<br /><br />Should be two yellow wires comming from the stator. THese have AC voltages on them. Then their should be a red wire that goes to the battery (may not be a direct link to it). THis is the charging wire. Easy way to check for charging is with a voltmeter. Check the voltage at the battery before cranking. Should be around 12.5 Volts. THen crank and let it run for a few min. THen recheck the voltage at the battery. It should be above 13 volts or a little above. This means the system is charging. If not you need to look further.<br /><br />May I suggest a manual. Worth every penny and you will save yourself alot of time.
Status
