charging system
BENJA
does a 76 1150 115hp o/b have a charging system? If so how do you hook it up to the battery?
katbird
Re: charging system
yes it has one. it is called a stator and located under the flywheel. it has 2 yellow wires comming out of it going to the rectifier. it is already hooked up. you need a volt meter to see if it is charging . my reads about 14 volts. if it stays at 12 then probably the stator is bad.
BENJA
Re: charging system
Thanks Ron Regan I'll get my volt meter out and check it <br /><br />Ben
