Charging system over voltage
Ncjoel
Suzuki 2006 115hp
Normal read 15.1v on fish finder and dash gauge, above 4000 rpm reads 16.3 alarm beeps a 1 code and dash gauge flickers at top limit. Drop rpm to 4000, alarm quits and voltage goes back to lower readings. Does this on regular basis. Any ideas?
GA_Boater
Welcome aboard.
Sounds like the voltage regulator has died.
tblshur
Ncjoel make sure all battery terminals and ground connection are shiny bright clean just a thought hope this helps
scoutabout
My 2004 90 yam was behaving in a similar manner. Replaced regulator and all was good. Yamaha tech I talked to seemed to feel a loose battery connection pooched it. Said to keep all connectors bright and tight always.
