charging problem
gwhjr98
Had a problem with my auto bilge pump.. wire broke and ended up with a lot of water in the boat. Did not get any in the engine but once I pumped all the water out went to start the boat but had to use a starter jumper pack. Got the engine started but the volt meter on the boat shows only 10-11 amps. The engine dies out. My first assumption is that the alternator is the problem. Any other thoughts? thanks
