Re: charging parallel batteries
Jim<br />Two batteries in parallel does not work very well. You would be better off to get one very big battery. The problem with two batteries in parallel is if a cell should die in either battery it will discharge both batteries. Having said that I also have two batteries. One runs everything the boat need to go, Starter, Trim and Tilt motors, Lights, Bilge blower, Bilge pump, Horn, Windsheild wiper, Trim Tabs. The other Runs all the electronics, Radio, Gps, Radar, Loran C, Fish finders.<br />Bateries charge in Parallel but thru a Battery Isolater. If one battery goes bad will not affect the other. Also have a battery switch to allow starter and boat to use second battery should first run down. Battery isolator does drop about .7 volts to both batteries but I have had no trouble with batteries. Mine have lasted about 6 years on average, much better than my cars and I do not know why.<br />I also use a 10 amp automatic charger to charge batteries and it works fine. The one I use just has a meter. You can set it to convential or maintenace free, and I always use the maintenance free setting setting for the boat. I ran two 10 guage wires to a plug on the front of the boat. Black wire goes to engine block, red wire goes to input terminal on battery isolator same as alternator wire. Reason I ran the plug up front was for two reasons. 1: I got tired of climing in under the cover and under engine cover or battery covers to hook up charger. 2: I have a 12 volt line that comes from the tow vechical and a plug that I can plug it to charge batteries while on the road. When I get home I always hook up battery charger and charge batteries while we unload the boat and clean the fish. I think this helps the batteries, as always use power after shut the engine off. Raising the motors, if at night leave the lights on until get everything put away and some times forget to turn off the electronic until in the tie down area. Takes about 15 to 30 minutes for charger to drop to zero. I also use charger about once a month in winter to charge batteries even if we have not used the boat. I have several battery charger but have not used the one that has the charge complete light. One I use has a meter and it will start at about 5 amps and drop to just off zero, less than 1/2 amp in 15 to 30 minutes after a day or night of boating. My boat is a I/O with a 40 amp alternator.
