Re: Charging fixed, thanks to all...
This past weekend I decided to check all of the fuses again. I pulled them all, there were 3, all different. One 30A at the battery terminal, a fat 50A fuse in the terminal box on the transom, and a short fuse near the engine block where the wires all plug together. All of the fuses tested fine with my multimeter. The 30A seemed a little corroded and I had some new ones in the box so I replaced it. I didn't have replacements for the others so I just cleaned them real good, and lightly sanded the ends. I also took my batteries to autozone and they tested good, so I put the trickle charger on them overnight.<br /><br />The next day I launched the boat, hoping my charing problems would be fixed, but unfortunately the problem was still there, my guage still showed ~11 volts.<br /><br />I rode out to the fishing hole and drowned some bait for a couple of hours while I anticipated the ride back with my wife driving the boat and me checking the voltage with my multimeter (she doesn't like to drive the boat).<br /><br />As we were leaving I was playing with my GPS, changing the data fields when I noticed that I had the option to display the current voltage digitally on the GPS. So I thought, well maybe this will at least tell me if my guage is wrong. I fired up the engine and headed back and noticed that my GPS was reading 14.1 volts, so I looked over at the analogue guage and it was also reading in the green between 13 and 14 volts. I couldn't believe it!<br /><br />Anyways, I monitored the GPS voltage reading all the way back to the ramp, and it stayed at around 14.1. The GPS always showed a little bit higher than the analogue guage, and at one point the voltage showed about 16 volts, which I know is high, but the analogue guage still showed between 13 and 14 volts - I guess the GPS is a little more sensitive.<br /><br />So maybe the fuse that I changed was the problem. I still don't know why it didn't start working right away, but maybe it's because when I first launched the boat the batteries were fully charged, but after a couple of hours of running the electronics while I was fishing the batteries were low enough to take a charge.<br /><br />Anyways, thanks to all that helped with this problem. The boat is running great. Now off to do some long overdue maintenance.
