Re: charging batteries
sounds like a lot of batteries!
LOL, I have 4 batts in my boat.
:facepalm:
As HC said, I would break the parallel connection before charging the trolling motor batteries. I have charged batteries connected parallel before, and it works, it's just not the best way to do it.
Actually, I would ditch the parallel connection and put an A-B-Both-off switch in so you are only running from 1 battery at a time. Most likely, both of those batteries will not stabilize to the exact same voltage, and after charging, the better battery will bleed off and stabilize to the marginal batteries voltage. IE: good batteries 12.6V bleeds off to the 12.4V of the marginal battery, making them both at 12.4V. I ran a parallel setup for years, but when I installed a battery switch and ran the batteries separate, I had longer run times off the 12V trolling motor.
Also, in a parallel setup, if 1 battery goes bad it's going to eventually ruin the other battery.
