Hi All.... I am changing a water pump for the first time ever on an outboard (1990 90hp rude) and I'd like some advice, if you would be so kind! (I have the origional service manual and the claymore manual)<br /><br />1. Are there subtitutes that I can use and buy at NAPA for these items (I live in small town with no boat shop)?<br /><br />*OMC Triple Guard Grease<br />*OMG Gasket Sealing Compound<br />*OMC Adhesive M<br />*OMC Moly Lube<br />*OMC Nut Lock<br /><br />2. When I take the gear box off, does the lubricant come out, or is it self contained in the unit?? I just changed it like 2 weeks ago, I'd like to avoid it if possible. If not, then there's no choice.<br /><br />3. Is there supposed to be a gasket between the gearcase and the mid-section where it bolts on? or is there some kind of liquid gasket I'm suposed to use?<br /><br />Thanks a lot for the help guys. I'm a noober with this stuff. I used to take my boat in to have stuff done, but you all inspired me to do it myself -- Therefore I ask dumb questions!<br /><br />Dennis
