Changing trim pump hose.
Fordiesel69
On a pre alpha 120/140 it looks like the high pressure hose goes thru the transom shield down low. How do you change this, not only can I not see it, but getting tools in there looks impossible. Any ideas?
Fishermark
Re: Changing trim pump hose.
Pull the manifold loose from the bottom of the transom assembly from the outside of the boat, then drop it down to access the hoses.
fishrdan
^^^ Yup
Use the old hose to pull a wire/string into the engine bay, that you can use to feed the new hose down to the manifold. You will need a new manifold gasket too.
