Originally posted by TheOilDoc:<br />
<br />Researching some of your older posts, it appears you de-carbed this outboard prior to using the Amsoil. The de-carb would be the primary reason that the engine now runs smoother and smokes less. You would find similar results using many other similar oils.
Ok, Now Im sure i know who you are.<br /><br /><br />If you would have "REALLY" looked at the previous posts, (which you never really do look closely, you would have seen that I did The decarbing before I switched to the synthetic, way before I actually switched, so I knew how it was performing with the Quicksilver. You actually think Im not sharper than that??? And Quicksilver isnt a bad oil, it is in fact a great oil as far as the regular oils go, and you really wont have any real problems using it, you can simply do better. Its also rated for air and water cooled, which I dont like in a regular oil. Im not concerned with a synthetic though. (IMHO)<br /><br />What you say "COULD HAVE BE TRUE", But it isnt.<br /><br />Isnt it amazing how far some will go to discredit someone???
<br /><br />Researching past posts, Not actually posting facts, changing your user name, Showing your true colors huh???
