Changing thermostat on Merc 4.3 and Perfect seal
Kubaat3lover
Hello,
i need to change my thermostat and found information on manual #25 page 6A-23 that:
IMPORTANT: Gasket has continuity rivets. Do not coat with Quicksilver Perfect Seal,
or Audio Warning Temperature Switch may not work properly.
and below there is an instruction :
5. Coat both sides of new thermostat housing gasket with Quicksilver Perfect Seal and
position on intake manifold.
So, conclusion is to use perfect seal or not?!
Thanks take care
GA_Boater
The instructions are warning about covering the rivet with PS and isn't saying don't use it. What step 5 should say;
5. Coat both sides of new thermostat housing gasket with Quicksilver Perfect Seal avoiding the rivets and
Kubaat3lover
Thank You! Tech English is not my mother language so sometimes it may be misleading,
take care
Btw.
on the older Manual Ive found this note:
do they mean the Oring /gasket or the bottom one?
