Re: Changing motors
IF the two motors have similar connections, it's not too bad a job. I'm in the process of replacing my 1994 Force 90 with a 1993 Force 150. I haven't finished the job, but the connections appear to be the same. My major steps were:
1. Disconnect the battery cables. If the cables on both engines are about the same length, you can just disconnect them at the battery. If they are different lengths, you'll have to disconnect them from the engine to so they can stay with the boat.
2. Disconnect the quick connect fuel lines at the engine. If they use the same fittings, that part is done.
3. Open the window where the cables and connections enter the front of the cowl. On mine there was a small plastic piece that held everything in place. Make notes or take photos so you can remember what went where.
4. Mark the throttle and shifter cables with tape so you can remember which is which. Disconnect the cables from the engine.
5. Disconnect the large electrical cable where it plugs into the engine.
6. Pull all of the above from the engine and stow it out of the way.
7. On my engine I also had two hoses that ran to the boat's instrument panel. One was attached near the thermostat and provided water pressure info. The other came from the lower unit and provided pressure for the speedometer. If you have these, disconnect them. If one boat has such gauges and the other doesn't, you'll need to swap fittings so the hoses can attach to the new engine.
8. Disconnect the steering cable where the inner cable attaches to the arm, and where the outer cable attaches to the engine.
9. Remove the steering cable if you can. On my boat I had to wait until the engine was partially lifted from the transom before there was enough wiggle room to get it out.
10. Attach your lift to support the weight of the engine and remove the transom bolts.
11. Lift the engine from the transom. Keep in mind that you'll need somewhere to rest one engine during the swap. I made a temporary stand out of heavy lumber.
12. Put it all back together in opposite order.
Good luck.
