I am attempting to change the LU oil on a Force 85. I see that it has a fill hole and a vent hole. I also see the allen screw at the botton drain hole.
Question- can the LU oil be pumped out and refilled from the top, or do I need to remove the drain screw?
Also, unlike other LU I have seen, do you need to fill it from the bottom-up, or do you use the fill hole? Has me confused.
Can anyone chime in?
