Changing Impeller in '55 'rude Fleetwin 7.5hp. Help!!!!
handifly
A small motor shop has been working on my 1955 Evinrude 7.5hp Fleetwin. They claim they have to detach the lower unit from the powerhead to change the impeller.
I looked at the exploded view in the manual which is supposed to be for all models 3hp-9.9. It looks like the impeller is located between the bottom 2 sections of the lower unit
Is there something peculiar to the '55 Fleetwin? I can't imagine a design requiring that much disassembly. Why should the top third of the lower unit need to come off at all?
Please help
handifly
Re: Changing Impeller in '55 'rude Fleetwin 7.5hp. Help!!!!
Just reading shop manual: says it is necessary grrrrr
HighTrim
Yes the powerhead comes off to access the shift rod connection.
However, this is not overly complicated, no matter what they tell you. Will likely need a new base gasket though. I can pull a powerhead in minutes, if all bolts co operate!
nwcove
jmo, but you are missing out on 75% of the enjoyment of these old motors!! and spending way to many $$ paying a shop to do the work. again.....jmo.
Chinewalker
And make sure the shop knows to put the upper driveshaft to crankshaft seal assembly goes together properly.
djboat100
Those old motors have a solid drive shaft--no way to unlink it from the powerhead without taking it off.
kfa4303
Banned
+1. while you do have to remove the power head, it's not hard. Changing the impeller is a simple DIY job that you can and should do for your self.
HighTrim
The drive shaft is not the issue, the issue is the shift rod connection which would hold you up. The drive shaft is splines and simply slides out of the powerhead.
djboat100
Correct, it's the shifting rod I was referring to. In more modern outboards the shift rod has a linkage halfway up that can be accessed and disconnected--in the fleetwin it's one piece.
djboat100
It's not hard if the power head bolts actually come out and aren't seized/broken off, which with a 60 year old motor is hardly a sure thing.
