Changing impeller/gear lube on 92' Evinrude 200XP
kspilot
Hello there, I am back with another question. I was wondering if it is very difficult to change out the impeller and change the gear lube on the lower unit. From what I gather, it appears that the impeller sits on a shaft that goes up the outdirive and was also told that the lower unit gear lube should be changed every year before winter. Is this an easy DIY project for the mechanically impaired?
OBJ
Re: Changing impeller/gear lube on 92' Evinrude 200XP
An OEM manual for your engine would be your best bet. It will give you step by step instructions for doing the job. It's a relativley easy job but if you have never done it before, a manual to guide you is a must.
