Looking for help. Thanks in advance.
I messed up the gears in my lower unit. I bought another one to rebuild but it turns out the lower in my motor does not have the same driver shaft as the one I bought. Mine has an extension so I can’t make it work as is. i want to swap the gears in to my lower so I can use my drive shaft. The current gear ratio is 2:1 and the new is 1.64:1. Do I need to match a prop to keep from damaging the motor?
