Re: Changing gear oil - newbie question
Stop by any Mercury dealer and pick up a quart of gear lube,new O-ring washers for the vent,fill and drain plugs.(always replace them at every change)
You can get a lube pump for about 6 bucks at Walmart.
Pull the bottom drain screw,the top fill and vent screws and let drain.
Slowly pump the new lube in from the bottom hole until it reaches the top or vent hole.
Put the top plug back in and quickly unscrew the lube pump and put the drain plug back in......
Wipe up the mess and thats pretty much it.
I usually recheck at the top fill plug after a run to make sure its full and any air was in it. It may need a slight top off but usually not.
