Changing Engines And Outdrives
Status
Not open for further replies.
bodine56
hello i have a omc outdrive on my 19ft searay and i was wondering if i can change it to a mercruser for i have on another boat. the omc fits 350 chevy and the mercruser fits 302 ford engine. with changing the belt housings will it fit? i wont to keep the 350 chevy on the mercruser. can use some help on this..<br /><br /> thanks bodine
f_inscreenname
Re: Changing Engines And Outdrives
Motors are about the same size. Not ever owning a OMC but I think you will have to do some transom work (diffrent size hole in the transom).
aerwin
what omc do you have? if it is the 400 or 800 it will not work without a major conversion. the transon hole has to be reduced, you will need to add power stearing, hydrolic pump for trim tilt and move the engine. this is not a cheap or easy job.
bodine56
I THINK IT IS THE 800 BUT IT DOES HAVE POWER STEERING AND TRIM AND TILT ON IT WITH THE RUBBER BOOT IN THE REAR FOR THE TRIM. I THOUGHT I WOULD I WOULD CHANGE THE RUBBER BOOT SO THE MERCRUSR WILL FIT RIGHT. THE OMC DOES HAVE A BIGGER HOLE IN THE BOOT WHERE IT GOES THREW THE TRANSOM. WILL THAT WORK? WOULD IT BE CHEPER TO PUT A NEW OMC OUTDRIVE IN IT OR TRY TO PUT MY MERCRUSER IN IT? MY OMC IS BROKEN..<br /><br /> BODINE56
D
DJ
Guest
bodine56,<br /><br />It can be done, you may have to do some boat stringer work.<br /><br />Also, the transom cut outs are completely different. You'll need to completely rework the transom.
Lark40
I've read similar OMC-to-Merc questions before. Generally, the consensus is to rebuild the OMC, as parts are still easy to get, and there is significant structural work to install a Merc.
aerwin
the 800 does not have hydralic power steering and the tilt is electric, I wish there was an easier way also, I am stuck with an 800 also
torxdrive
if you want to put a merc in that boat you will have to glass iin the hole in the back and thenhave someone that nows how to cut and drill the holes into the back in the rite place it is cridicale were it goes then new strings at the right higth it is a mager job
Boatist
Bodine56<br />First I wish you would turn off your caps lock. all caps is considered rude and yelling. Your OMC 800 is a stringer mounted system and the merc is a transom mounted system. To change you must rebuild the transom then have someone cut out holes to match the merc template. After that still have to buy compelte outdrive. Each of these steps is big bucks. The other option in to fix your OMC 800. About the worst thing that is common is the water pump to drive shaft splines goes bad and must be replaced $800 to $1000. Much cheaper to fix your OMC. What is the problem with it anyway???
bodine56
The problem with the omc is one of the ears is broke off where it attaches to the boat and tilts on other than that it is ok other than needs the oil changed and new seals put in the outdrive and a new shift cable and waterpump imp.i thought it be easier just to change the outdrive because i allready have a mercruser outdrive...but i guess not.<br /><br /> bodine 56
bodine56
Richey <br /><br /> i dont know what the would be worth ...i know what a new one cost....unless u wont to make me an offer for it........where is a good place in dallas to go have the hole fiberglassed up? does anyone know a good cheep place....i will take all engine and outdrive out of it and the only thing they will have to do is fix the hole i will do the rest......<br /> thanx bodine56
Status
