Re: Changing Coolant ON FWC
Level engine. Remove the block drains, pull the hose from the engine circulation pump. This will drain the heat exchanger and the pump. Refill with a 50/50 mix of regular green antifreeze.
If you have a full cooling system (including manifolds) drain them too before refilling.
Run engine on muffs and make sure you have no air bubbles in the system.
