Re: changing a tire on tow vehicle when trailering
I have a feeling I might get a flat while towing my utility trailer (5x9) about 4 hours. Just a hunch I guess. Question is, do I need to remove the trailer from the hitch BEFORE I jack up the truck?
Thanks...
You have a small trailer.
Block the tires like was mentioned.
They have smaller floor jacks that would suit your application.
HOWEVER !!!!!!!!!!!!!!
You really need to actually change the tire NOW to see how it goes. Nothing worse than trying to figure out HOW to do it when your in that situation.
Hook it up. Change it and see what you have to do.
If it won't work well, then you know you have to unhook.
I can't tell you the things i use to see on the road with people trying to change tires on cars and trailers.
Do yourself a favor and then if it does happen you'll go "MMMM no biggie, I've done it before."
Have a safe trip.
