kennygeorge
- May 4, 2019
- 1
I guess I should have done one at a time and tested, but I wanted to get a "new-to-me" 1973 65hp 3-cylinder Johnson ready for the lake. I changed the starter motor, solenoid, impeller and thermostat. The old thermostat was frozen open with a small opening, so I knew I was on the right track.
I have now run it in a barrel of water, that never got hot, for 15 minutes. No water ever came out of the pee holes.
I'm puzzled as to what is wrong:
I've attached pictures of the old thermostat showing the opening, the installation of the new thermostat and the impeller installation. I used hose clamps to get the impeller small enough to go into the housing and had the blades go the same direction as my engine manual. I did make sure the woodruff key was installed correctly and the impeller was spinning when I turned the shaft by hand.
- Did I install the impeller wrong?
- Is the thermostat bad?
- Did I not run it long enough? (but I don't want to warp the heads with heat)
