Re: change tiller syst. to remote control
Yes, it could be done for some bucks. You would need to get ahold of a control box(Shift/Throttle Control)with ignition, throttle and shift cables, Wiring harness, Steering linkage at the motor and a few other parts to make it work. But it can be done! If you can find some of the main parts used, you should come in under $500.00. E-bay has controls sometimes. The wiring harness may be found there also, but you may wind up getting that at a dealer, as well as the steering linkage.
