change shift lever. 6 HP Johnso
pflathead
ups did a job on this motor shipping it, broke shift handle and bent shaft. This looks like a one piece unit and it looks like the power head may have to come off to replace. Any suggestions? Also need a cover, ups got it too. Thanks again. Great site guys.<br /><br />Pflathead <br /><br />1987 6 hp Model: J6RCUD<br />SN: B7389919
rodbolt
Re: change shift lever. 6 HP Johnso
yep its power head removal time.<br /> be careful not to lose any of the lower crank seal parts. and make sure the seal retaining roll pin is actually in the drive shaft.
pflathead
Thanks for the fast replies.<br /><br />Pflathead
Chinewalker
On a 1987 model 6hp there's no roll pin in the driveshaft or any of the other bits to worry about. You might not even have to pullt the powerhead if you can get at the two 3/8" bolts that hold the cover over the shifter gears. Might have to pull the recoil and the carb off. There's a single bolt holding the end of the shifter to the gear and the handle and shaft ought to pull right out. <br />- Scott
phatmanmike
doesnt UPS have shipping insurance. same thing happened to a friend of mine, and they paid him for the motor, but his was a 2001 25hp merc.
