Change of crankshaft
MOTION LINE
Here is one for you TOHATSU GURU;
What is the difference of the crankshaft old and new
model affected MFS 8A/MFS 9.8A: 010322XD
Service bulletin from Tohatsu No.04-008
Description Old P/N New P/N Qty Interchangeability Parts List Ref. No.
Crankshaft
3V1-00030-0 3V1-00030-1 1 A 3-1
The part seems visually the same but where exactly is it modified?
By the way the new 8-9.8 4-stroke Tohatsu is one of the best engines I have ever seen!
TOHATSU GURU
Re: Change of crankshaft
I have no idea, although in the back of my mind I keep thinking "coating". The part was changed after the first month of engine production. The service bulletin says it was a machining change so it was probably releated to a vendor change. There have not been any warranty claims ever filed over a crankshaft so I doubt that there was a problem. I'll see if anyone at Tohatsu can remember why, but I doubt anyone in the U.S. knows.
TOHATSU GURU
And the response from Tohatsu is...They don't either, Oddly enough the part number has changed back to the original part number now. Their best guess:
Vendor change.
None of the tech guys at Tohatsu were there when this model came out and like I said, all I remember was a "coating" change which could have been anything.
