Chain Anchor
rczolman
I was told that I need to make a "chain anchor" in order to fish a local river due to bottom debris. Can someone explain to me what this is and how to make it. I was told that I need about 35lbs of chain. <br /><br />Thanks, FC :confused:
Capt Joe
Re: Chain Anchor
Re chain attached to anchor - the chain ensures that the anchor does not lift when pressure is applied to the line. It's weight acts as a shock absorber. If bottom debris is a major problem ie fallen trees, rocks etc., you need a reef anchor that will straighten out if stuck.<br /><br />Try here for info:<br /> http://www.mrl.cofc.edu/text/Reefs.html
oregonducker
Re: Chain Anchor
Frank,<br />See your post in the freshwater fishing section. By the way it's a no no to post the same topic in multiple forums.
