Century Riviera 5 meter dilemma
JJJZJ
I recently just had my starter lock up on me and chew up the teeth on the flywheel ring. I have pulled the engine, but cannot find a serial number for the exact model, but i am 95 percent sure its a mercury 470(aka 170). I talked to one dealer who said that i might as well junk the motor as getting a flywheel or ring gear is impossible, anyone have any advice as to what my best course of action is?
Don S
Re: Century Riviera 5 meter dilemma
Measure the ID and OD of the ring gear itself, and count the teeth. Then check with NAPA and see if they have one that will fit.
The flywheels from Merc are NLA (No Longer Available).
JJJZJ
k, I can do that, im praying someone somehow this will work out, this is my first boat and if i have to scrap it due to some stupid flywheel, im gunna be feeling pretty blue, i have(had) grand plans for my baby. Any other ideas anyone? are there specialty ring gear shops that my aftermarket rings maybe? any other ideas?
You just Might be able to find 1 on ebay,..........
If you search Long Enough........
Bt Doctur
just look for a ring gear .heat and knock off the old, heat and install the new
JJJZJ
im trying to find a ring gear, but its posing to be quite a problem. Due to the serial number being unfindable on the engine block, im not sure of the exact motor. Ill post some pics, maybe you guys can help. and are there are good places to look for a ring gear?
On a side note too, I went to Napa and they matched the ring gear to an old ford motor. 157 teeth, 12" ID and something like 13.13 OD. It comes tuesday and was 25 bucks so we will see if it works.....
im enclosing some pics of my engine too
Don S
If it says 170 on it, as you posted in your original post, then that is probably what it is.
It has the small 3" heat exchanger and the proper expansion tank/elbow for a 170.
The engine was a Mercruiser designed aluminum block using a Ford 460 head so I would guess it's not a long stretch that the crank and flywheel may also be Ford or Ford influenced.
Capt Ken
The crank is different only because it only has four rod journals instead of the eight but the best I remember the flywheel is the same as the 460 ford.
JJJZJ
yah im taking the starter to them tomorrow to make sure the teeth line up and then ill post how that goes.....
