CD unit problem force 85 OB 1987
kenjiroo
--------------------------------------------------------------------------------<br />hi all, i only got 2 cylinders working on my force (build in 1987 )instead of 3 ...looks like i have problems with the CDI units...the orange wires who feeds the ignition coil are working..but 2 red ones of both CDI dont make any contact(coincidence???)....could it be that the 2 r broke or is it an electric problem i do not know of..the second red one of the CDI is used to run the 4th cylinder , but i only got an engine with 3 cylinders..so i tought to use that one because it's never been used..but even that one isn't working..pls need some help..greetz from Belgium
sony2001
Re: CD unit problem force 85 OB 1987
You are correct. The 2 CD's can run a 4 cylinder.<br />To check the CD, switch it with the good one. Get spark! If not then could be the trigger. You've changed the stator I believe.
kenjiroo
correct, i changed the stator , but looks like this was broke 2...i replaced a new CD but still no spark on the middle cylinder....so, guess it must be my trigger??
sony2001
Check the coil for continuity.<br />Try not to be a parts changer without testing it.<br />«««««««««««That will get to be expensive and good parts get thrown out. When Ì'm home I'll review the manuel for more ideas. Parlez vous le francais?
kenjiroo
hi, yeah french should be our second lang. the other part of belgium is french , overhere we speak flemish :) , well i replaced one CD unit and guess what...problem not solved...now i will ask the repare shop to to fix it and take the cd unit of my reparecosts...hope they will because over here they r'nt cheap (280 $ ) i replaced the stator already , this was broke aswell...so there's only one left..the trigger!! last time i buy a second handed bayliner :-(<br />but hey , maybe 400 buks and i'm ready to rock'n'roll in one of the difficult sea's in the world NORTHSEA ,lol
