cd-18......5.5hp....how do i turn it off!!
piperdog
hello,,is there a cut out switch for the cd-18,if not how do you turn it off (without running out of fuel and disconnecting the spark leads ),,thanks piperdog
OptsyEagle
Re: cd-18......5.5hp....how do i turn it off!!
It should die once you turn the tiller handle full off.
emckelvy
Turn the throttle to the lowest speed setting and if it's still running, pull out the choke. That's about all there is to kill the Beast.
Later models had a kill switch and you could retro-fit one to your motor. You'd need to mount a switch to the motor cowling; drill a hole in the magneto plate (or perhaps you'll find an empty hole already there); install a rubber grommet and route a pair of wires inside the plate, one wire connected to each set of points (where the condenser wire and coil wire screw onto the points). The kill switch will electrically connect both points together and this'll kill spark.
Here's an inexpensive aftermarket kill switch available here at the iBoats Store, that could be easily adapted to your motor:
http://www.iboats.com/Universal-Kil...0632425--**********.693229627--view_id.167979
If you want to use something that looks "period", take a look on eBay for old Johnson/Evinrude parts.
HTH........ed
CaptainRonn
Just choke it man I have the same issue
