Hello everyone! quick questune. have a 1964 16' evinrude tri-hull with 1978 merc 115hp engine. Once on a plane, anything harder than a gentle turn will start the prop cavitating (starboard is worse than port turn). its obviously not the original engine or prop. Engine is mounted correctly and shaft is right length (plate about 1 inch below keel). Trimming dosnt seem to affect it.<br /><br />any ideas? Im thinking prop not cupped correctly, but not really sure. anything else? skeg is also sheared off half way...could this have something to do with it?<br /><br />also, this is my first tri-hull. seems they should 'skid' in a turn anyway (inside hull not allowing heel into turn?). boat is overpowered with 115, maybe Im pushing boat past design charictaristics?<br /><br />thanks!
