Re: Cavitation Plate, location
UU wrote, "The anti-cavitation plate as a rule should be level (and parallel) with the keel line on a planing hull. Depending on hull design (especially the rear part of the bottom) this may need to be adjusted."<br /><br />No, as a rule of thumb the outboard should be mounted per the outboard and boat manufacturers rigging spec. This is rarely level with the keel line on a planing hull. It is usually slightly below the keel line (for the reasons stated below). I've seen specifications 2" or more below keel line. Joe's post is accurate for the most part.<br /><br />HowieDean wrote: "...but Cavation plat hight is meaningless.... Where your prop shaft is in relation to the bottom of your boat is what you need to worry about..."<br /><br />Nice outboard setup HD, but the cavitation plate is a vital instrument in maintaining bow lift, stability, proper rpm, proper cooling, and control (safety) of your boat. I don't think Charger 183 plans on doing 105 mph. I would not recommend a 12 1/2" lift.<br /><br />The best advice here is to work with your prop. Cupping will make a big difference in the cavitation problem. You may want a little less pitch and more cupping. I'd get a jack plate before I cut the transom. Your Evin dealer will have the rigging specs for your cavitation plate.
