Re: cavitation plate issue
(I found this on the web. Note where it says "air ingestion". So, an "anti-ventalation" plate would help prevent cavitaion, so you could refer to it as a "anti-cavitation" plate)<br /><br />SUBJECT : Cavitation 1-3<br /><br />Cavitation means that cavities are forming in the liquid that we are pumping. When these cavities form at the suction of the pump several things happen all at once.<br /><br />We experience a loss in capacity. <br />We can no longer build the same head (pressure) <br />The efficiency drops. <br />The cavities or bubbles will collapse when they pass into the higher regions of pressure causing noise, vibration, and damage to many of the components. <br />The cavities form for five basic reasons and it is common practice to lump all of them into the general classification of cavitation. This is an error because we will learn that to correct each of these conditions we must understand why they occur and how to fix them. Here they are in no particular order :<br /><br />Vaporization <br />Air ingestion <br />Internal recirculation <br />Flow turbulence <br />The Vane Passing Syndrome
