I have a Pursuit 2150 CC that was repowered with a 2003 Yamaha 200 HP Saltwater Series 2. The old Engine was a 200 HP Yamaha Saltwater Series 1. After running the boat the performance seems to be way off and very sloppy. I cannot get the bow to lift. As soon as I pitch out the engine the propeller blows out and I lose bite. This prop was on the old engine and I did not have this problem before. Both engines are 25" shaft. I did notice that the cavitation plate is about 2-3" above the bottom of the boat. Are the bubbles that are being trapped under the hull when I'm under way running under the cavitation plate and getting sucked into the water stream that feeds the propeller? Is the cavitation plate to high? I'm running a 3 blade 13.75x17 wheel uncupped. I also notice that I cannot get the same top speed as I used too. Before the repower, 41.5mph at wot running 5500 rpm. Now 38.5mph at wot running 5200 rpm. All help and experience will help. Thank you. Czkidd
