johnrmclean
- Jun 12, 2007
- 82
So while doing a pre start tune up of my 50Hp mariner/Merc that had been stored for about 10 years I found some significantly deteriorating wires. I found the insulation on the white, and white and black striped wires on my trigger assembly were deteriorating so bad it was just crumbling off the wire. This deterioration was basically from one end to the other so it was impossible to save them. In addition the wire itself looked to be oxidizing. As a result i bought a new trigger assembly. Now I have found a similar situation on my stater assembly. The deterioration is also on two white wires. these are the main wires to the connection block. The difference here is that the problem seems to be very limited to a specific 1/2 - 3/4 inch area where they may have also been exposed and compromised to some cutting. The insulation here did not crumble but I was able to peal it off easily for about an inch. one wire looked like it was starting to oxidize also. Since the rest of the wire seems to be in tack and a new stator is many dollars I'm looking to try and repair, replace or somehow save these two wires. Any feed back with similar experiences , insite to the cause of this or other advice from those more knowledgeable would be great appreciated.
