I finally found a source of a leak and it is the grab rail mount. When I removed it a small chip of gelcoat came off with it. The chip is so mall that it can be covered by the mount of the grab rail. I went ahead and cleaned up the caulk off the boat and around the grab rail. My question is can I just re-caulk everything or should I first fill in the small chip w/ marinetex that is going to be covered up by the grab rail, then caulk? I am using a poly caulk that I got from west marine as they did not carry small amounts of 4200. I do have some 5200, though people told me to use that for only under the water line stuff. I would like to get this sealed up ASAP as it has been raining a lot up here and I don't want any more water in my cuddy cabin.
Thanks in advance,
Hostage
Thanks in advance,
Hostage
