First of all - this is my first stab at a furnace. Our house is going on 3 years old - I haven't touched the furnace since I moved in(besides changing filter and dusting) We decided to turn on the furnace for the first time today and nothing happened. The fan would blow on when on the on poisition but nothing else. <br /> I took off the access panels and cleaned everything off - nothing. <br /> Turned off power then went over all the connections on the main board and followed wires to check for anything strange(checked the fuse and taped the door switch down) <br /> I set thermostat on 80, reset the switch on the inside of the furnace and turned on the power. The fan kicked in, the ignitor got red hot but it seems like the gas was never released(is there supposed to be a series of clicks like a gas grill?). It shuts off and starts the blinking light process. <br /> What should I be checking next? I assume the control valve isnt opening - either the circuit control board or the switch? Hopefully someone out there knows a bit about this - Thanks!!!<br />Don
