Carlson glastron sp boat
ringo111
Guys,thinking about buying 1970 Carlson glastron deep hull add says James bond style.does anybody have one of these boats,or have any experience with this type of boat and their handling ability in rough water.this one is powered by 60hp outboard . Thanks
26aftcab454
Re: Carlson glastron sp boat
I think your talking a late 70's Early 80's GT 160
16 feet with 85hp-115hp is good towards 55mph ( Bond had a 135hp on his)
a 60 hp will be a slow turd.:(
make sure it's not rotted out.
444
The james bond boat was actually the glastron gt-150, the 15'er. That part is even mentioned in the glastron sales brochures from the 70's. I believe they were produced from 1971-80 and a few other companies have produced knock offs/reproductions of the design, which is what mine is. Also, glastron made many other similar looking but slightly different hulls in the same era.
I have one with a 84 mercury 90hp inline 6. You're right, the bond boat had an evinrude 135. My 84 mercury is more comparable to a 1970's 115hp since that same motor was rated at 115hp in the 70's when the hull was built before they changed from crankshaft hp ratings to propshaft hp ratings.
Do you have any pictures or have you seen it to verify it's the same one I'm talking about? There's nothing "deep" about this hull, it's a shallow vee speedboat hull. When on plane the boat sits very flat on the water(nose not high up in the air) with very little of the boat in the water. The hull is rated at a dry weight of 600 and something pounds. It's a small boat, easy for one person to move the boat/trailer around by hand. Super easy to launch and retrieve.
If the lake water is as smooth as glass, the boat is a dream. With the 90 horse merc, mine can really fly. It's small, nimble, maneuverable and responsive. The downside is she doesn't do so well in rough water. Because the boat is so light and so little of it in the water when on plane, you feel every wave when you hit it. Where a heavier deep vee bowrider will plow through waves without barely feeling them, this little boat bounces right off them so you do get jerked around on windy days when you're boating somewhere without cover. I have watched how other boats react when mine is getting tossed around by the waves so I know this to be true. Not dangerous, harmful or hard to handle by any means, just expect to feel it when the front of the boat bounces off waves.
I have seen other examples of these GT-150's powered by 60hp outboards so I think you will be fine there. My 1984 merc 90hp is way overkill, I don't even need to take it over half throttle to get it to plane quickly.
Frank Acampora
First two are the V153 and third is the GT150
Sometime in the early 70s, Glastron made an agreement with Carlson boats opr Joe-blow Carlson, designer I forget which exactly-- to make the Glastron/Carlson hulls which were very respected boats. They were about 16 to 18 feet long, looked very similar to regular Glastron hulls, and were relatively shallow vee go-fast boats. Very pretty and upscale from the Glastron models. One or two MAY have been in the chase scene from Live and Let Die, but they were NOT the definitive James Bond boat as shown in the photo above.
Rough water? Depends upon your tolerance and skill.
I have a V153, GT150, V163, and the little tri hull that went into the pool in the Bond picture (V145?). I have had the V153 in Lake Champlain and on the Chesapeake in waves from 1 Foot to 4 feet high. The big stuff is scary in a little boat like that.
ringo111
thanks ,boat is a 20 ft it has a cuddy with a hatch,port side has a small door that leads to bow where to adults can sleep.owner says it is a carlson glaston ,he said boat is rated for 150 hp wish i had pics,to show thanks
ringo111
thanks,nice looking boats . the one i am looking at is a 20ft ,it has a cuddy where 2 people can lie down,on top of cuddy it has a small hatch on top owner says it is 1970 .your pics dont look this boat ,wish i had pics to show,thanks.
ringo111
thanks.three boats in pics ,dont look like boat in question,this one is 20 ft has a cuddy,where 2 adults can sleep on top of cuddy is a small hatch,it is rated for 150 hp,owner had trouble with it and put on a 60 hp,the hull is very sleek looking ,wish i had pics, thanks
mr 88
I hope your wrong about the 60 hp statement in your first post. A 20' er with a 60 is way underpowered.
ringo111
Link wouldn,t open up, is there another one I could try thanks
ringo111
Went thru brochures from 60's to 80's and didn't see anything similar. I have pictures on my computer but I don't know how to put them on the iboat forums. Is it possible for you to send me your email address so I can send you the pictures so you can look at the boat yourself. My email address is EDIT
444
Hit the reply button, then click the go advanced button. Scroll down a bit is a button called manage attachments. With that you can choose the pic off your computer and upload it to this thread.
ringo111
Thanks four help.is it possible some one might recognize this model Carlson glastron and comment on it .I know pics are small thanks.
ringo111
Top of bow is way different the bow on one I am looking at has a hatch on top.hard to se fm picture windshield location is completely different .hard to se fm picture.I checked boatsfm 60s to 80s still nothing looking familiar what gives.I phone the owner to day,he said it's just a Carlson glastron,nothing else thanks.
Dismiss
K b.
dorelse
Well, your only other choice is the G/C Conquest...the Conrithian didn't have the bow hatch from what I remember. The sales brochure even describes the bow hatch. I didn't realize they were that different...never actually seen one in person...even rarer most likely.
http://www.classicglastron.com/70gl-carlsons-cont-web.html
dorelse
Found the ad on Kijiji - Halifax. That is a 1970 Glastron Carlson Conquest. Only made 1 year. Has the same hull as the earlier Corinthian's, but with a bow hatch as you described. Assuming this is the boat. Did you purchase it? (Its listed as sold.) There's a pretty active Classic Glastron Carlson club that'd love to see more details & photos:
http://halifax.kijiji.ca/c-cars-vehicles-boats-watercraft-powerboats-motorboats-20-ft-cuddy-with-60-evenrude-W0QQAdIdZ272674405
ringo111
yes, i bought it and it's on the way here on a truck. Should have it on Monday or Tuesday. I will post some good pics as soon as I can. Thanks for all your help.
