Re: Carburetor Theory - 1978 70HP (3cyl)
Actually if you look carefully at the front of the crankcase you can see the flow pattern. both the top and bottom carbs feed the center cyl. thru the red blocks, each carb has a reed block behind it with 4 reeds on the top and 4 reeds on the bottom, the 4 reeds on top of the top block feed #1 cyl and the 4 on the bottom feed the center cyl. the bottom reed blocks 4 top reeds also feed number 2 cyl. and the 4 on the bottom of the reed block feed # 3 cyl. So 1 & 3 are each feed with 4 reeds and # 2 is feed with 8 reeds and I wonder why the don't idle well?
