I have (2) older Evinrude engines. First, a 1978 70hp, and second a 1975 135hp. I have done carb rebuilds on both of these engines. One thing that I have not seen discussed on here is throttle shaft wear. I found out through testing that excessive wear can cause a lean condition. The 70hp had about .02-.03" wear on both shafts. A common repair is to enlarge the idle jet size a few sizes to remedy the extra air entering. The 135 had about .015-.02" wear on the throttle shafts. Being a machinist, I machined o-ring grooves into the carburetor body to seal the shaft to the housing. This repair has solved several issues. One test that I learned from a senior mechanic is to apply heavy grease around the exterior throttle shafts to "seal" them to the carb body. Also, it is my opinion that this might be an overlooked issue being the return springs are on the shaft and don't allow them to flop around during a rebuild. I am interested in hearing everyone's thoughts. Please comment!
