Hello, still tinkering with my 56 15hp johnson. <br />I replaced all coils, points, condensors and cleaned and kitted carb. fuel system seems to hold pressure fine. I believed that it was running great, idled smooth, etc. But having a new problem: If I tilt the motor over the transom while there is tank pressure, it begins to leak fuel out some small hole in the top of the carb. Then, when I lower the motor back down and try to start, motor will hit a few times then not start, may not start for several hours. Will eventually start later or the next day. Seems to help if I release the pressure on the tank before I tilt motor up. Am I doing something wrong? I am learning as I go along here, any help appreciated!
